Guest cfitzpat Posted August 7, 2006 Posted August 7, 2006 Hi all, just taken on system with the above. SD works ok, but when it triggers, it sends a msg saying it has detected an intruder, fire and panic all in one go! Would seem for some reason it is triggering on all 3 instead of just one. Anyone else come across this? Found the wirng diagram from Scantronics site, but not sure if it is wired incorrectly or faulty. Any help appreciated. Chris
Darren Cooper Posted August 7, 2006 Posted August 7, 2006 Sounds to me like the common message has had all trigger messages recorded on it. Maybe re-program the unit and then test. The views above are mine and NOT those of my employer.
sparky83 Posted August 7, 2006 Posted August 7, 2006 Put your meter across the outputs and you can see which outputs/ channels are being triggered, then you can see whether its the panel or the speech dialler at fault. Trade Member
