Guest axe Posted August 9, 2006 Posted August 9, 2006 Hi, how long does the battery normaly last in a bell box ? Thanks
Guest Posted August 9, 2006 Posted August 9, 2006 until it fails........... ni-cad maybe 10+ years service life.
Guest Posted August 9, 2006 Posted August 9, 2006 An RMV or routine maintenance visit on your system should be carried out at least once a year on your system. During this test, the engineer disconnects the hold off at the panel end - your bell box should then sound - if it doesnt or sounds like a strangled parrot - then more than likely your SAB battery needs changing -this is one way the battery's condition in the bell box/SAB can be gauged.
