Guest raymor Posted August 10, 2006 Posted August 10, 2006 having installed a panel with remote keypad I find that the warning bleeper on `Entry/ Exit` is not loud enough. I have adjusted the volume control in the key without success. It was suggested by the Webmaster that a 12v buzzer or 16ohm speaker connected across the speaker terminals should overcome this problem. I,ve tried the buzzer suggestion, nothing ???
Adi Posted August 10, 2006 Posted August 10, 2006 A buzzer will not work connected to the speaker terminals only a speaker will. I really can't be ar**** with it anymore.
