Guest Landlord Posted January 21, 2004 Posted January 21, 2004 A Homewatch 418 FM Wireless system was installed around 1997 and several tennants later it's not working! The key fobs arm & disarm the central unit (which is hardwired to a bell box). I've checked that the DIL switches are all coded the same and replaced the batteries in each of the 3 PIRs (last recorded change 1999!). Two of the three PIR's worked intermitantly and the bell box sounded ok, but these have now stopped working completely and the third PIR never worked. Do PIR's deteriorate - do they need cleaning? How do you check if the bell box battery is ok? Can you recommend anything to get it working? Thanks Landlord
morph Posted January 22, 2004 Posted January 22, 2004 Get a local alarm company in to check it out. Colin.
