Best Place For A Panel
tom25
Hi, Where would the best place to put the control panel for an alarm?
In the loft, Wardrobe, garage, under the stairs
Im stuck on where the best place would be
thanks
is it safe to put a panel in the loft due to changing temperatures?, 9Gets very hot in summer and very cold in winter)
Do a risk assesment, where would you think is the last place on your property a person would look for an alarm panel?
cheers
well they wouldnt check the loft but is a panel safe from things like fires in rapidly changing temperatures?
ok thanks, will look around for the best place and try and avoid the loft
If your house is on fire an alarm system isnt what you want its a fire alarm system.
Now your talking things run in FP Cable and different issues.
I think he means starting a fire. No it wouldnt but hot temperatures reduce battery life so you would have to change it yearly.
