Securitech Active 5 Fault Indication - Help Required
Guest hudengineer
Guest hudengineer
My Mother-in-Law's house alarm has stopped working normally. Until today, it was fine, and had been reliable. Now, it displays:
Power, steady green, I think, from memory
Day - Unlit, or very dim orange
Zone 1 Steady Red
Zone 2 Unlit
Zone 3 Unlit
Zone 4 Flashing Red, about 1 Hz
Zone 5 Flashing Red, about 1 Hz
When the code is entered, the LEDs do not change state, but a two tone warning sounds indefinitely until the code is re-entered. I'm guessing that the flashing LEDs each indicate a fault??
All four of the PIRs appear to be working; detecting my presence and bliking the LEDs on when I am in range, and with a DMM on the contacts for the front door, it appears that the reed switch is functional too. I'm not aware of any other sensors in the house, nor which zones have what on them (the M-I-L is in hospital, and has enough to worry about right now without knowing that her house alarm isn't working), but I'm suspicious about two zones going faulty simultaneously, if I have interpreted the LEDs correctly. The alarm is seviced annually, but the maintenance engineer I spoke to was no help whatsoever. Any ideas?
i think all this needs is a rest but about 6 years since ive seen one. try code and #
Yeah it must be a bit tired! :P
James meant 'a reset' as it looks like the alarm has activated with the steady zone light showing the first zone to have tripped and the flashing ones have activated afterwards (or the other way round).
If you don't know......ask.
Guest hudengineer
lol damned keyboard lol
rest lol yeah meant reset
My keyboard does that to me, too, from time to time! Thanks for the tip. Hopefully, we don't need any other 'special' codes to sort matters; our usual one should be OK? And, is the 'Code' key actually the *, because there only appears to be the standard 0-9, * and #. Oh, engage brain - 'code' is the four digit code!!
