Guest Dyfrig Roberts Posted August 13, 2006 Posted August 13, 2006 `Hi I am a Computer technician for a small company and we have a Server room that is airconditioned and only allows certain persons access to the room We try and keep the servers working at a peak condition and at a constant temperature We have a fully monitored alarm system that goes to a Central Station My problem is last night I happened to have to go into the office to pick something up and discovered that the Air Conditioning had failed Does anyone know of a temperature sensor we could link into the Alarm system to give a low and high reading that could alert the station so one of the keyholders could be informed
Guest Posted August 13, 2006 Posted August 13, 2006 It can be done, and you would need to speak to the company that maintains your alarm for you.
james.wilson Posted August 13, 2006 Posted August 13, 2006 We have used temprature monituring units before and I forget the manufacturer. Some panels accepts a temp probe and a voltage input that you can set on the panel itself securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
camerabloke Posted August 13, 2006 Posted August 13, 2006 or you can use a relay Eucam Security Systems 0845 4630 746 www.eucam.co.uk
james.wilson Posted August 13, 2006 Posted August 13, 2006 or you can use a relay He could wire a relay of the aircon power b ut that wouldnt give him his hi-lo temp monitoring, unless you know of a relay i dont mate.. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest quantum Posted August 13, 2006 Posted August 13, 2006 We use APC environmental monitoring products, for Fluid, Temperature / humidity, smoke monitoring, but they do loads of other sensors too. I remotely manage several server rooms via the WAN / Internet. The APC exipment can be set to warn you via email, SMS etc, If you already use APC UPS, there's a chance you can just add an environmental monitoring card and sensor, works out fairly cheap. http://www.apc.com/products/family/index.cfm?id=26 http://www.apc.com/products/category.cfm?id=17
breff Posted August 13, 2006 Posted August 13, 2006 What about a Menvier SD2 dialler, it has a temperature sensor built in and can phone you if the temperature is exceeded. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
IPAlarms Posted August 16, 2006 Posted August 16, 2006 It would be ideal if you had one of the panels mentioned by jameswilson as you would be able to alert the central station. The UPS mentioned by quantum and SD2 dialler are also good ideas for contacting you directly without the involvement of the central station. My company have an IP dialler called DigiNet that has analogue inputs for temperature monitoring. It also has digital inputs if you decide to trigger it with a temperature device that has a relay. Either way, it will send an alarm signal to a central station or alert you directly via email. It also has digital outputs that would allow you (or a CS operator) to log in and switch on backup devices via your web browser if required. Some of my customers use it with network monitoring software products like 'Nagios' or 'What's up Gold' as the outgoing alarm message of the DigiNet is customisable. Hope this helps. Free Alarm Monitoring over the Internet from IP Alarms
Drew Posted August 16, 2006 Posted August 16, 2006 We are just looking at this kind of thing. I know the problem - you just want to get the feature installed without a huge infrstructure. This particular function would be very useful for us too, so I may try this today: A Net2 I/O board will accept an input from a standard room thermostat. This in conjunction with Net2 software will enable an email and or an SMS message to be sent in the event that the thermostat changes state. This is designed to be part of an access control system - Net2 would obviously be the right choice for your server room door too but it can be done as a feature in its own right and would be reasonably cost effective. With spare inputs and outputs, there are bound to be other things you can control in a server room. If you're interested in this idea, have a look at our web site. Supply is trade only, so if you want to take it further, repost and one of the guys here will be able to help, I am sure. Drew Hoggatt Managing Director Paxton Access Ltd Follow this link for important legal information
arfur mo Posted August 16, 2006 Posted August 16, 2006 hi all, if you need this feaure surely 2 x digital room stats (Hi Lo) could be wired to a couple of zones and configured as 'monitored inputs' of the alarm or access control system. depends on the kit installed but easy peazy on most bigger panels regs alan If you think education is difficult, try being stupid!!!!
