Guest phil day Posted August 13, 2006 Posted August 13, 2006 hello all after some advice have accord xpc alarm system with radio sensors in the garage. the bell is on lcd panel with number 8 flashing. i removed radio cover and removed battery to see what type and have now got 7 on as well.....(take it this is a tamper icon)....main problem is cant set alarm at all and cant omit zone 8....have tried **** standard code but get Ce now...any help much appreciated....will it all work if i just replace the radio battery.....the system is not monitored..
james.wilson Posted August 13, 2006 Posted August 13, 2006 what is zone 8, it would appear there was no problem with the radio pir zone 7 till you opened it securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest phil day Posted August 13, 2006 Posted August 13, 2006 according to the paperwork i have zone 8 is a indication that the radio battery is low....
james.wilson Posted August 13, 2006 Posted August 13, 2006 Well someone who has experirence with the xpc better correct me if im wrong but if i remeber the accord was an 8 zone panel that could take an rf keypad. I would have thought that zone 8 was a device not a global low battery alarm. So yuor only using circits 1 - 7 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Guest phil day Posted August 14, 2006 Posted August 14, 2006 zone 5 fitted to garage door....magnetic reed contact zone 6 is set to tamper, when activated reports trouble with radio equipment zone 7 is set to tamper,when activated reports a tamper with radio equipment zone 8 is set to tamper,when activated report radio battery is low and reqs replacing this is what is on the paperwork i have if it helps the radio kit is a visionic power code class v transmitter and reciever
morph Posted August 14, 2006 Posted August 14, 2006 zone 8 is set to tamper,when activated report radio battery is low and reqs replacing If the system is wired to show a low battery as zone 8 and you have not changed the battery, the system will not reset until you have remove the source of the fault ie, change the battery
antinode Posted August 14, 2006 Posted August 14, 2006 Sounds like you have the MTC100 transmitter (little white box with a thin wire antennae coming out of it and red LED). The Powercode stuff uses a 3v Lithium battery. Replacing this and closing the lid on the transmitter should clear zone 7 and 8. Trade Member
antinode Posted August 14, 2006 Posted August 14, 2006 now im confused i thought he had a wireless accord xpc so would have ademco pir's, Now he has visonic stuff? Seems like he's got like a standard Accord XPC (did'nt know there was a wireless one?) with a Visonic wireless setup for a (probably) detached garage. Trade Member
Guest phil day Posted August 14, 2006 Posted August 14, 2006 thanks for all the advice of out to get battery....hope it works
Guest phil day Posted August 14, 2006 Posted August 14, 2006 ok changed battery but still flashing 7 and 8.....think it might be set to engineer reset after tamper. WARNING DO NOT POST DEFAULT ENGINEER/USER CODES IN THE PUBLIC FORUMS
