Guest Posted August 15, 2006 Posted August 15, 2006 CJTELECTRICS said: ... a lot of knowledge ... hmm - how to say it - .... rather don't use wireless.. ALSEC said: As for panels - the galaxy is a walk in the park compared to the ATS - which we (for some unknown reason) are fitting in some newer jobs..... i've heard so..
mikhail Posted September 11, 2006 Author Posted September 11, 2006 Do you remember me? I've started the topic. So, the problem is sold. I've made aerial from 3mm cooper wire and solder its conductors to aerail on PF RIO PCB. And now keyfobs work perfectly from up to needed 40m outside over metal fence. Thank you all.
mjw Posted September 11, 2006 Posted September 11, 2006 CJTELECTRICS said: jameswilson said: CJTELECTRICS said: Service Engineer said: Quote Spotter - is that the calculation for a full wave??Most wireless devices will use a 1/4 wave antenna, so if you calcutating full wave sizes don't forget to divide the result by 4. i used a wirefree rio n a cctv job in the west mids area and do you think we culd make it work in the ned te ompany ended up cabi the unit from the building to the gate to activate the cctv system. what im trying to say is you have to have a lot of knowledge to use this kit as i found out. Cant disagree with you there mate! have you used this equip much? i noticed that the instructions of installation was **** AND TECH support was not hepful at all Tech support wouldnt be much help AS this ISNT GALAXY KIT..it is made by a third party....NOT honeywell You can do a software upgrade on the older rf portals but you do need correct lead and of couse software B) mjw said: CJTELECTRICS said: jameswilson said: CJTELECTRICS said: Service Engineer said: Quote Spotter - is that the calculation for a full wave??Most wireless devices will use a 1/4 wave antenna, so if you calcutating full wave sizes don't forget to divide the result by 4. i used a wirefree rio n a cctv job in the west mids area and do you think we culd make it work in the ned te ompany ended up cabi the unit from the building to the gate to activate the cctv system. what im trying to say is you have to have a lot of knowledge to use this kit as i found out. Cant disagree with you there mate! have you used this equip much? i noticed that the instructions of installation was **** AND TECH support was not hepful at all Tech support wouldnt be much help AS this ISNT GALAXY KIT..it is made by a third party....NOT honeywell You can do a software upgrade on the older rf portals but you do need correct lead and of couse software B) Sorry was meant to tell you software upgrade DOES extend operating range
Guest Posted September 11, 2006 Posted September 11, 2006 mjw - I have Changed your reply colour in your post, and bolded your reply text for slight ease of reading.... Dave.
mjw Posted September 12, 2006 Posted September 12, 2006 DNS Security said: mjw - I have Changed your reply colour in your post, and bolded your reply text for slight ease of reading....Dave. Thanks not sure how it changed????.......may be by accident as i didnt do it???????
