Guest colinsc Posted August 15, 2006 Posted August 15, 2006 Hello, I have a scantronic 9800+ system in my house. The internal sounder alarm went off on numreous occassions last night, but stopped when I put in my user code. The rp (remote keypad fault) is flashing on the LED dsiplay and the service and fault lights are on. Can you please tell me how i can disconnect the keypad from the system, and stop the internal sounder and external bell going off. Is it possible to remove the keypad (and disconnect the system) without permanantly setting off the alarm? The alarm system is unset, but still the internal sounders are going off. I stay in the Falkirk area (Central Scotland). Unfortunately the original service engineer has retired, and I do not know which company to contact now. , Colin
Guest rjbsec Posted August 15, 2006 Posted August 15, 2006 Hello,I have a scantronic 9800+ system in my house. The internal sounder alarm went off on numreous occassions last night, but stopped when I put in my user code. The rp (remote keypad fault) is flashing on the LED dsiplay and the service and fault lights are on. Can you please tell me how i can disconnect the keypad from the system, and stop the internal sounder and external bell going off. Is it possible to remove the keypad (and disconnect the system) without permanantly setting off the alarm? The alarm system is unset, but still the internal sounders are going off. I stay in the Falkirk area (Central Scotland). Unfortunately the original service engineer has retired, and I do not know which company to contact now. , Colin We cannot tell you how to disable your alarm for obvious reasons - it may simply be in need of a new battery; contact a local installer.
Guest Posted August 15, 2006 Posted August 15, 2006 Please note that if you disconnected your system, your external sounder is battery backed up, and may sound independently, even with the rest of the system powered down.
morph Posted August 15, 2006 Posted August 15, 2006 We can assist you if you still need help or you can look here or have a look in the yellow pages.
Gopher Posted August 15, 2006 Posted August 15, 2006 I agree with alarmgard, you need to have an engineer look at it. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
Guest colinsc Posted August 16, 2006 Posted August 16, 2006 Hello, Thanks to Colin from Alarm Guard for helping me sort the problem with my alarm. , Colin Sorry that should have been Colin from Alarmgard.
