Guest Richw Posted January 22, 2004 Posted January 22, 2004 Not really sure if I should have put this question here?? but it is kind of a control panel query!! just wondered what the general view of the Texecom premier 88 panel is? GOOD BAD???
Red Fox UK Posted January 22, 2004 Posted January 22, 2004 Hi Richw, Yes, that panel is quite a good one, full of features and is normally used in business environments - but suitable for home too... It is a great panel, as all Texecom panels are... Warren Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Guest dale Posted January 23, 2004 Posted January 23, 2004 I have the Premier 816 in my house, and its excellent. You can do loads of stuff with the outputs such as control access to doors, switch relays to turn outside lights on. The best part is the remote administration if you have a com module in it, as you can dial into it from anywhere and re-programme it without having to do a site visit for the customer. All in all a nice bit of kit! Dale
Red Fox UK Posted January 23, 2004 Posted January 23, 2004 switch relays to turn outside lights on Interesting, Looks like im in for a upgrade Red Fox | Hosting Affordable and Reliable UK Based Web Hosting
Guest Richw Posted January 23, 2004 Posted January 23, 2004 Yeah, I'm also interested in that idea, would be good to use the random timer to switch internal lights on when the system is armed, more info on how this is done would be really useful!!!! I wanted to use the 60 XP id as mentioned in the install guide, but texecom don't seem to know much about it??? ie. when its going to be released Rich
Guest dale Posted January 23, 2004 Posted January 23, 2004 The best thing to do is email Texecom tech support they will probably be able to tell you more info on some of the features as well as give you a rough estimate of when the 60XP is gonna be released. They seem a really freindly bunch so drop em an email. Dale
breff Posted January 26, 2004 Posted January 26, 2004 The Premier is probably one of the most flexible panels I've ever used. Got an 88 in my house, it turns on the hall light during entry between 16.00 and 07.00, and brings on the hall & landing lights if a smoke detector goes off! It also texts me on mobile if anything is activated. I dial it up from my laptop using my nokia infrared and reprogram it. Texecom are VERY helpful, even rewriting the software when we needed new outputs. Try it , you'll like it Breff The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Jimbob Posted January 28, 2004 Posted January 28, 2004 I agree with Breff Texecom panels are excellent Tech Support First Class And if you have the time, have a tour around the site in Haslingdon.......well worth the time And for those not sure about the panels training days can be arranged
Guest granleyss Posted January 29, 2004 Posted January 29, 2004 We rang texecom the other day they are sending out a sample panel of the premier 24 with a keypad and proxy built in for us to use with our monitoring customers as the matrix from pyronix is garbage our engineers are complaining about the programming but wouldn,t touch the R8 or compact etc we are just sticking with the premier and the galaxy panels can,t go wrong.
