Veritas 8C Control Panel
Guest Squiss
Apologies if this is a dumb female question! :huh:
The numbers on the keypad of said control panel have all but vanished and I would like to replace it. I've found loads of suppliers on the net from which I can get a replacement panel but I only require the keypad. Does anyone know if this is possible?
Thanks! :D
Squiss,
Check you e-mail! :)
Regards
Steve
Steve Kendall
Plymstock Security Systems
Its a doddle to add a seperate remote keypad loads of info and manual on Yahoo email back if you need more
fireman_sam @bigfoot,com :fyi:
