Guest slim Posted January 24, 2004 Posted January 24, 2004 Hi all, im new here, very impressed with the site Can anyone help, please - got a flashing tamper on a Bentley V2. All loops are closed, Ta.
geov Posted January 24, 2004 Posted January 24, 2004 Equally unfamiliar with the panel, but you may want to check the sounder, panel and RKP tampers too.
Guest slim Posted January 24, 2004 Posted January 24, 2004 back again, loops are double poled, panel and bell tampers are ok. speaker doesnt have a tamper and no rkp on system (keyswitch job). also tried re-init, reset w/dog and reset panel' system is bells only and I dont want to change panel - as it is about 15 years old and hasn't given her a problem so far. Thanx again.
mr silcox Posted January 24, 2004 Posted January 24, 2004 hi if there is no zone indication the a/t means either final exit negative leg aux circuit negative leg bell negative leg front and back panel tamper switches if its a flashing tamper its the aux /pa thats at fault hope it's of some help
Guest slim Posted January 25, 2004 Posted January 25, 2004 Sorry, I may have misled you earlier. All loops are closed (i.e. Closed cct), all less than 15 ohms, bell return drops 350mV. The system consists of 6 ccts, F/E, PA. Panel battery was changed in Aug 2003 and still reads 7.2A/h. I'll speak to sub tomorrow to see if she wants to update the system, Many thanx-------Ray
