Premier Lcdlp Keypads
whibbs
can any one till me if it's possabile to get the texecom premier LCDLP KEYPAD to show when the system is set or unset as when you look at the keypad you can not till if the system is set or not
wayne
Wayne Hibbs
You can turn the Green LED to be on when unset and Off when unset.
Just trying to do my job
can you till how to do this as iam not do i set the keypad to show info led ?
Wayne Hibbs
The standards do state that there should be no indication if the system is set or unset.
You sure Pete?, I thought you wasnt allowed to indicate a set system, not an unset system.
If you want to not install to the standards, and do what you want it to although not recommended, just untick the box that says enable en50131 in system configuration then it will show the system status.
Trade Member
A lert
WTF is A LERT............ ahh its the standards isnt it........not supposed to show status chaps!
Yer yer i know, you all said it b4 me.
cheers
program the keypad output to Type-Alarm-21(Armed) or 22(Full armed) or 23(Part armed)
then in keypad setup turn on option O-Info Led>Output
No systems status info can be shown at all, which is why you can even see mains status anymore.
Mick Gates
Regional Sales Manager- Intrusion Products
Bosch Security
www.boschsecurity.co.uk
