Connect Bell Box To Control Panel
Guest sammar
Guest sammar
Hi
I have searched these forums for a similar topic but have been unable to find anything useful. I am trying to connect a Reson 8 Bell Box to an Accenta G3 Mini Panel. I have followed the instructions that came with the bell box - which only states I need 5 wires, the sixth one, blue is not needed. Is that right? And if so, does this not connect back to the Panel?
On looking at the instructions with the Panel they are somewhat different and use all 6 wires - however I don
Guest Alarm Guard
Just leave the blue wire unused. That will be fine. You don't need to do anything with it at all... except making sure it doesn't touch anything else.
Guest sammar
Thank you so much for the advise. I really appreciate it. I won't need to be scared when I switch it all on now! :)
Guest rjbsec
The panel provides a 12-volt positive output for the strobe light but many bellboxes don't require another positive input for that, hence you don't need it.
