Guest PaulMaddocks Posted August 30, 2006 Posted August 30, 2006 Hi all, First post on the forum, so far found it very useful but I have a couple of specific questions I need some answers to before I can wire up my panel. I have a scantronic 9651 with 5 Honeywell PIRs and 1 smoke detector. I have checked the manual for the control box and just need to confirm the following: Power for PIRs etc are all connected the AUX power connector strip (as this is the only power output I can see on the board). The alarm connections on the PIRs (each connected on a different zone) appear to share a connection block, e.g for Zones 1 and 2 there are 3 connections, am i correct in assuming that Zone 1 PIR Alarm + goes to first connection, return from Zone 1 middle, Zone 2 return to middle and Zone 2 Alarm to 3rd connection. (Apologies if this is totally off the mark but I could not see how else it goes) Finally, could someone be kind enough to post a very quick diagram on FSL wiring, I understand you need to wire the 2 different resistors into each sensor, but not got a grasp on which to where. Again sorry for the obvious questions but I am keen to get my head around this and get it all done myself. Programming I got no problems, just the physical. (Also posted on the DIY install section)
avcctv Posted August 31, 2006 Posted August 31, 2006 Hi all,First post on the forum, so far found it very useful but I have a couple of specific questions I need some answers to before I can wire up my panel. I have a scantronic 9651 with 5 Honeywell PIRs and 1 smoke detector. I have checked the manual for the control box and just need to confirm the following: Power for PIRs etc are all connected the AUX power connector strip (as this is the only power output I can see on the board). The alarm connections on the PIRs (each connected on a different zone) appear to share a connection block, e.g for Zones 1 and 2 there are 3 connections, am i correct in assuming that Zone 1 PIR Alarm + goes to first connection, return from Zone 1 middle, Zone 2 return to middle and Zone 2 Alarm to 3rd connection. (Apologies if this is totally off the mark but I could not see how else it goes) Finally, could someone be kind enough to post a very quick diagram on FSL wiring, I understand you need to wire the 2 different resistors into each sensor, but not got a grasp on which to where. Again sorry for the obvious questions but I am keen to get my head around this and get it all done myself. Programming I got no problems, just the physical. (Also posted on the DIY install section) Can't help you there, they are questions for the Trade only section. Sorry The older I get, the faster I was.
Guest Posted August 31, 2006 Posted August 31, 2006 Please start only one topic per query. Your other query is here .
