Guest Sparks Posted September 1, 2006 Posted September 1, 2006 Any TS2500 experts in!? I can't seem to figure out (even after reading the manual!) how to program the outputs on the keypads! If I go into Engineering menu 3, option 8 (Equipment O/P) I can program the XNODE outputs (A and B) but cant see where I can do this to the keypads. For example, XNode on address 1,02 (Network 1, Device 02) has a keypad set as Keypad 1 connected to it's keypad network. How do I program the output on this keypad? Thanks!
Guest Posted September 1, 2006 Posted September 1, 2006 is your rkp off the x node if so no's 1&3 will follow ouput a, 2&4 b
breff Posted September 1, 2006 Posted September 1, 2006 Any TS2500 experts in!?I can't seem to figure out (even after reading the manual!) how to program the outputs on the keypads! If I go into Engineering menu 3, option 8 (Equipment O/P) I can program the XNODE outputs (A and B) but cant see where I can do this to the keypads. For example, XNode on address 1,02 (Network 1, Device 02) has a keypad set as Keypad 1 connected to it's keypad network. How do I program the output on this keypad? Thanks! As Mr Happy says you program output A of the xnode for keypads 1 and 3, and output B for keypads 2 and 4, so in your example you would program Xnode 1 network 2 output A The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
