Premier 48 And Output Programing
whibbs
i have fitted a premier 48 panel and need some help set up the panel output to drive 12 v relays conected to flood lights 1 have all relay up and running and now need to program the outputs. so that any zone entered will switch on the outputs . but before the alarm goes active there is a total of 18 zones i have set 1 zone as entey / exit (delay 30 seconds) and the rest of them are set to guard what is the best setting to use
i have looked at setting the output to entey/ exit but only works on 1 zone
also i tried setting it to the output to alarm but it will not switch relays on the entry zones unless the entey timer ends. please help me thanks
Wayne Hibbs
2 outputs mate
1 as entry and one as alarm, as long as the texecom switches all outputs the same way ie switch neg with resiive pull up, then connect them in parrelel
thanks will try this never throught of doing it this way thanks very much for your help
Wayne Hibbs
What is it that you want to actually achieve???
When do you want the lights to come on???
It can probably be achieved with one custom output
You can programme the output by time scheduling so they come on at night only, for an activation.
We also have a relay set up for a courtesy light for entry time.
Just trying to do my job
Not enough info.
What do you want the lights to do? Do you want them to activate with any zone... or just on alarm activation... and in daylight or not..... and for how long??
lights on at night for 3mins and to actvate on any zone
Wayne Hibbs
Try connecting it to a GDC lighting system, (opel)
