tyco res internal sa siren
Guest terrylidd
Guest terrylidd
the tyco internal sa siren has 6 terminal connections.
R- Negative Trigger
H+ Positive hold-off supply
H- Negative hold-off supply
Bat- Battery
Bat+ Battery
RTN Negative tamper return
the Accord xpc has
LS
Aux+
For loud speaker.
Please help Thanks
Hi All,
Right, Do the following.
Int Siren = Accord XPC = function
R- = BELL- = -VE Trigger
H+ = BELL+ = +VE Hold off
H- = BTMP- = -VE Hold off
RTN = BTMP-R = -VE Return
The siren should have a little battery in it, the red and black wires from this go to batt + and batt- respectivley
Hope this helps you out,
Regards
Bellman.
