Alec B Posted September 3, 2006 Posted September 3, 2006 Does anyone know what panels they install. Also are they any good. I'm about to do a takeover on one that my friend has inherited on a recent house move.
j.paul Posted September 3, 2006 Posted September 3, 2006 B)--><div class='quotetop'>QUOTE(Alec B @ Sep 3 2006, 07:03 AM) 117213[/snapback]</div><div class='quotemain'><!--quotec--> Does anyone know what panels they install. Also are they any good. I'm about to do a takeover on one that my friend has inherited on a recent house move. They used DSC panels (Power 832,608 or the Envoy) Great panels but a lot of installers didn't like them (or couldn't understand them ) The only problem you will have is BG had their own default engineer code in the panel There are no stupid questions, but there are a LOT of inquisitive idiots.
Alec B Posted September 3, 2006 Author Posted September 3, 2006 for the quick reply. I will get myself some manuals and have a good look through. Although if I default I would be stuck, wouldn't I, as I will be left with a panel with no engineer code at all?
j.paul Posted September 3, 2006 Posted September 3, 2006 for the quick reply. I will get myself some manuals and have a good look through. Although if I default I would be stuck, wouldn't I, as I will be left with a panel with no engineer code at all? If the panel is defaulted it will go back to BG owns code. If the phone line is still in the panel, then it can be defaulted and reprogramed using U/D There are no stupid questions, but there are a LOT of inquisitive idiots.
mjw Posted September 3, 2006 Posted September 3, 2006 B)--> QUOTE(Alec B @ Sep 3 2006, 08:03 AM) 117213[/snapback] Does anyone know what panels they install. Also are they any good. I'm about to do a takeover on one that my friend has inherited on a recent house move. If you speak to tony at dsc he can dial in and some times default engineers code
j.paul Posted September 3, 2006 Posted September 3, 2006 You can also get BG to return the panel back to standard DSC defaults, so you can take the system over (there will be a small charge for this ) There are no stupid questions, but there are a LOT of inquisitive idiots.
mjw Posted September 3, 2006 Posted September 3, 2006 You can also get BG to return the panel back to standard DSC defaults, so you can take the system over (there will be a small charge for this ) only thing is if you ask tony nicely he will do it F.O.C
Alec B Posted September 4, 2006 Author Posted September 4, 2006 Thanks for the advice. Will keep you posted if I get any problems.
