Alarm Protection Posted October 15, 2008 Posted October 15, 2008 Hi David I will have to get a magnifier glass to see as the writing is so small! Or is it my eyesight! Will post back tomm. !
BestGear Posted October 15, 2008 Posted October 15, 2008 Hi DavidI will have to get a magnifier glass to see as the writing is so small! Or is it my eyesight! Will post back tomm. Hi I dont think the picture attachment worked, so here it is again, hopefully... D
arfur mo Posted October 15, 2008 Posted October 15, 2008 just an idea on this thread, i have a HTC Touch Diamond phone which has a good high res screen, also one of SQ's alien dvrs indoors. i used WiFi and my phone display to set up the camera views. which set me thiking as to if there was a way to hook in a WiFi access point to a camera or DVR output for site use. often you go to a site all that is needed is a realign or to check after cleaning all is well, so having a convenient way of seeing the image without wire or needing to open the housing on a wet day could be very handy imo. regs alan If you think education is difficult, try being stupid!!!!
BestGear Posted October 15, 2008 Posted October 15, 2008 just an idea on this thread,i have a HTC Touch Diamond phone which has a good high res screen, also one of SQ's alien dvrs indoors. i used WiFi and my phone display to set up the camera views. which set me thiking as to if there was a way to hook in a WiFi access point to a camera or DVR output for site use. often you go to a site all that is needed is a realign or to check after cleaning all is well, so having a convenient way of seeing the image without wire or needing to open the housing on a wet day could be very handy imo. regs alan Alan..that is possible, there are a number of single port video servers around...axis being one. With this you would just plug in the composite video into the box, then into ethernet... so assume you have an access point to gain wireless connectivity.... Other alternative is a cheapo pc or laptop with one of the cheapo capture cards... these all have webservers....and you could even have peer to peer wireless (usb even) so that you dont need an access point... Could be worth developing.... David
BestGear Posted October 20, 2008 Posted October 20, 2008 Hi DavidI will have to get a magnifier glass to see as the writing is so small! Or is it my eyesight! Will post back tomm. Hi - any update...? Sorry for hassling! David
j.paul Posted October 21, 2008 Posted October 21, 2008 Well at 3am this morning I could have bounced my $%$%%$ of the wall... Been on change 2 days, lasted 5 min on site, %$% There are no stupid questions, but there are a LOT of inquisitive idiots.
Spaceman Posted October 25, 2008 Posted October 25, 2008 Well at 3am this morning I could have bounced my $%$%%$ of the wall...Been on change 2 days, lasted 5 min on site, %$%
BestGear Posted October 25, 2008 Posted October 25, 2008 Had mine for short time, charged twice (properly) hardly used, it wont hold a charge. Sent back for repair. Good unit but this apears to be a common problem. Hi - dont know if you read one of my earlier replies... I replaced the batteries with the largest capacity cells I could find... which ended up being from 7dayshop... Just a shame mine is a pile of scrap...unless i get some component IDs from some kind 337 owner...(hint...) David
