Sterling 10 Panel Problems
Guest jwclark
Guest jwclark
Does anyone have a installation/engineer manual for the Pyronix Sterling 10?
I have carefully moved the panel to a new location but since rewiring the panel will not come alive. I am confident that the wiring is correct and can see about 14v at the panel. I dare not remove the cover to the main unit without the manual to check for fuses etc as without a working panel may not be able to disable the alarm after triggering tamper. Any ideas?
James
Guest jwclark
Solved the problem - the Aux fuse had blown. Thanks for help.
James
