whibbs Posted September 4, 2006 Posted September 4, 2006 can any one till me the best why to get a premier 48 to send text messages should i use a speech + text massage dialer or a com2400 dig modem not sure what i should fit Wayne Hibbs
breff Posted September 4, 2006 Posted September 4, 2006 Use the Com2400, it sends zone text as well. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted September 8, 2006 Author Posted September 8, 2006 can any one help mwwith this topic have the fitted com2400 as books says but it will not connect to the sms center all i get is failed can hear it dial if you pick th e phone please help Wayne Hibbs
whibbs Posted September 8, 2006 Author Posted September 8, 2006 not sure how do i find out Wayne Hibbs
Guest Posted September 8, 2006 Posted September 8, 2006 not sure how do i find out Who is your phone line with - which company? You need to contact them and enable SMS on your line - some charge for this, not all. Regards, Dave.
whibbs Posted September 8, 2006 Author Posted September 8, 2006 my line is with bt i have untill to day been using the texecom speech text dialer and that works fine so sms om my line must be switch on? Wayne Hibbs
breff Posted September 8, 2006 Posted September 8, 2006 What software version do you have? There is a problem with versions 7.2 to 7.5 but I think it only affected Prem 24s The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Posted September 8, 2006 Posted September 8, 2006 my line is with bt i have untill to day been using the texecom speech text dialer and that works fine so sms om my line must be switch on? Wasn't that speech - rather than SMS though, that you were using before?
