breff Posted September 8, 2006 Posted September 8, 2006 Have you programmed it via Wintex? If so PM me your .cif, .tdf and .thf files and password(if applied) and I'll take a look at the programming. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted September 8, 2006 Author Posted September 8, 2006 one that to note stated that my panel is a premier 48 but forgeting thats the one at work we fitted mys is a primer 24 sorry about thsi a bad mouth sorry sorry Wayne Hibbs
breff Posted September 8, 2006 Posted September 8, 2006 Ring Texecom Tech support tomorrow, i think you definately have a panel with the software fault. Problem is with the 24s they cant be flash upgraded on site like 48s and above. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted September 9, 2006 Author Posted September 9, 2006 phoned tech support no one there it's saturday will have to try monday since fitting the com2400 i can now longer send texts via the speech and text dialler any ideas. Wayne Hibbs
whibbs Posted September 9, 2006 Author Posted September 9, 2006 not sure of my total ren how do i find out Wayne Hibbs
Guest Posted September 9, 2006 Posted September 9, 2006 each item 1=ren, unless the the babt label says different, support of 4ren then a ren booster is required.
