OPTIMA XM PROBS
Guest Dave W
When I only have 1 or 2 lights left to switch off, the alarm goes off. Does anyone have any ideas?
sounds to me like your alarm is wired into yours lights at the junction box.could be an idea to get an electrician out to check yours mains supply. have you had the alarm long or have you inherited the system when you moved in.do you know if the alarm has been serviced recently or not.
pete B)
pete .................
Any comments/opinions posted are my own and not that of my employers.
The problem has changed slightly. The panel alarmed last night for no reason in the middle of the night. Could it be the battery?
