kevinaskew Posted September 8, 2006 Posted September 8, 2006 We are currently installing a BT Inspiration system at our Hospital Radio Station. We have connected the cables and powered up the system. The featurephones now display the following INSPIRATION British Telecom NET BTE 2.49/49 Comms OK But we can get no further that that, none of the buttons do anything. Please HELP Thanks Kevin Askew Chairman Radio Nene Valley Northampton
Simon_B Posted September 8, 2006 Posted September 8, 2006 Failing Bootup then if all featurephones (i.e. more than 1) showing this. Power down system, use ASP. Remove all cable connections, pull all circuits board (including Line PSTN/ISDN, Voicemail, Extension Expansion) out of the system leaving you with 0+6 motherboard only. Power on system, see if it boots up normally. If it does, process of elimination to see if you have a bad connection or faulty add-on card/circuit board. Could just be poor connection to motherboard. Regards Simon ToneTel Telecom www.tonetel.co.uk
kevinaskew Posted September 9, 2006 Author Posted September 9, 2006 Hi Simon, Thanks for your advice, I removed all the cards and reinstalled individually. It would appear that the socket on the motherboard for the first expansion card is causing the problem. are there any jumpers etc associated with this connection? There is a small red led on the motherboard near to what looks like a battery (could be a capacitor) near L1/L2/L3/L4. What does this led indicate? Thanks Kevin
Simon_B Posted September 10, 2006 Posted September 10, 2006 kevinaskew said: Hi Simon,Thanks for your advice, I removed all the cards and reinstalled individually. It would appear that the socket on the motherboard for the first expansion card is causing the problem. are there any jumpers etc associated with this connection? There is a small red led on the motherboard near to what looks like a battery (could be a capacitor) near L1/L2/L3/L4. What does this led indicate? Thanks Kevin No jumper or switches for it, check for loose wires etc that may be causing a short, give it a good shake. Try and remake the connection, give it a good push then retry turning on. Test the expansion board in the other connector. This way you can prove whether it is just a dodgy connector etc or you have a faulty expansion board. The Red LED is a status indicator, Flashing is normal operating condition, if it is solid on or off then you have a problem normally at boot-up, I would imagine you are getting solid on currently whilst having the problem. Regards Simon ToneTel Telecom www.tonetel.co.uk
