Additional Power Supply
steve
to be fair to all the members on here and all tradean you know how to do the panel but not how to wire a psu which is very basic, im a little worried by that!
best of luck steve hope you dont take offence as none is meant
colin
as i have said previously, I have no knowledge of psu's. The first bit of resarch I did was on here, hence the questions. Thanks for your help
i wish you luck steve,
i still think you would bennifit from an experiened engineers input and urg you to seek it, you don't want to find you need another cable after everthings plastered, or if you later have false alarms will you be able to trace the fault?.
an experienced engineer will forsee nd build out avoiding many many possible problems, others would just not see as an issue, and this starts from the simplest of things, like how to join 2 wires properly. thats not knocking you mate, even good installation engineers get rollocked from good service engineers when they get called out to a dopey bit of work.
regs
alan
