Adi Posted August 21, 2007 Posted August 21, 2007 Ive re read it again, if its just above the fuse then its the live terminal, im now confused. the earth is above the live then its neutral. Kiddies playing with adult toys. I really can't be ar**** with it anymore.
breff Posted August 21, 2007 Posted August 21, 2007 if it is and he connected to that and it didnt all go boom then he should get his wife and kids to safety Plastic panel with no connection to earth Angus. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
UKflyer Posted August 21, 2007 Posted August 21, 2007 Plastic panel with no connection to earth Angus. Thanks Breff, I thought I was right .... Immediately above and attached to the fuse is the live connection Above that is a SPARE terminal with no connection to the transformer earth as indicated in the manual (which by the way is drawn upside down) And above that is the neutral connection
Guest anguscanplay Posted August 21, 2007 Posted August 21, 2007 Plastic panel with no connection to earth Angus. cool so no cable protection either ( breaths in through teeth ) its always a good idea but hey its his install
camerabloke Posted August 21, 2007 Posted August 21, 2007 are you a sparks angus? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest anguscanplay Posted August 21, 2007 Posted August 21, 2007 are you a sparks angus? its the bangs that scare me , not the sparks lol. as said I prefer to include the earth for cable protection as per manf advice
UKflyer Posted August 22, 2007 Posted August 22, 2007 its the bangs that scare me , not the sparks lol. as said I prefer to include the earth for cable protection as per manf advice Angus, let's get this clear, I'm up for safety in all walks of life! As I have already said there is no obvious earth connection via the terminal block as suggested by the installation manual Have you ever fitted/serviced one of these panels? If so what did you do with the mains lead earth? (Keep it clean haha) Are you suggesting fiddling with the metalwork of the transformer in order to make an earth connection??
alterEGO Posted August 22, 2007 Posted August 22, 2007 Angus, let's get this clear, I'm up for safety in all walks of life!As I have already said there is no obvious earth connection via the terminal block as suggested by the installation manual Have you ever fitted/serviced one of these panels? If so what did you do with the mains lead earth? (Keep it clean haha) Are you suggesting fiddling with the metalwork of the transformer in order to make an earth connection?? i have worked on many of these [don't like them but service/fault] and they [i'm sure] had the standard 3 terminal connection for mains, earth being one of them.
Guest anguscanplay Posted August 22, 2007 Posted August 22, 2007 Angus, let's get this clear, I'm up for safety in all walks of life!As I have already said there is no obvious earth connection via the terminal block as suggested by the installation manual Have you ever fitted/serviced one of these panels? If so what did you do with the mains lead earth? (Keep it clean haha) Are you suggesting fiddling with the metalwork of the transformer in order to make an earth connection?? i have worked on many of these [don't like them but service/fault] and they [i'm sure] had the standard 3 terminal connection for mains, earth being one of them. enough of an answer for you ? - have a look in the next manual you see for a plastic panel , it will tell you to terminate the earth in the unused terminal of the fused conector block thingy . so we agree then that although the panel doesnt need earthing as its already double insulated ( hence the 2 squares symbol moulded onto the casing ) and because the cable is a permenant connection ( unlike a plug and socket ) and because we need to take the live to earth readings as part of the handover paperwork...........................blah blah blah as I said its a DIY install so he can do it how he wants - cant he ?
