Texecom Veritas R8 Plus
lapat
forum reaches new low :whistle:
I think we'll bring this to a conclusion chaps .....
Yes there is a 3-way 'Euro Type' fused terminal block, BUT on the control panel side only the live and neutral are wired .... ie no earth to the transformer
Hence I have connected the mains earth to what amounts to a spare terminal ....... PHEW!!
Guest Dave the alarm man
I'am thinking wally...................
you bother with a cpc on the flex?
or the FCU?
you got FCU?
WTF? FCU CPC TLA? Wally's use TLA's, or to try to show they know something you don't. :rolleyes:
Please explain in English for everyone's benefit.
(TLA = Three Letter Acronym. :whistle: )
dumbing down it for the numpties :rolleyes:
you bother with a cpc on the flex? used 2092Y or 2093Y
or the FCU? could you be bothered to connect an earth incoming or exiting the FCU
you got FCU? Fused Connection Unit? switched / unswitch fuse value cable size?
okay for the randy amateurs?
Says it all really...
So what is CPC then in your language?
And for the record, as you couldn't be bothered to explain, 2092Y and 2093Y are 2-core and 3-core PVC flex (circular heat-resistant to BS6141). :ranting:
Circuit Protection Conductor
fallen into my trap you've had to google for that :whistle: add 100 & you get bog standard round flex :P
Guest anguscanplay
so if he had connected the earth ( as we all agree we should ) where did the " spare " terminal come from hmmm ?
fallen into my trap
:hmm:
I thought the idea here was to help the original poster, which is what I was trying to do.
Childish games hardly contribute do they? :no:
No, you will have to excuse "Dave the Alarm Man" he's not really a "Happy Chap" and doesn't wish to share his wisdom on the public.
nope but they while away the hour's, BTW the OP may like to know the lillte fused conector has earth marking moulding into the termials
colin, I think wisdom should have been the bit in inverted commas ;)
