Galaxy Bellbox Connections
Guest platty1435
Guest platty1435
Hi Could anyone tell me the connections for a ventcroft bellbox to a galaxy 520 panel.
thats a serious panel mate, and if you dont know that, your going to have some serious issues with it
Agreed, thats a high end panel I'd consult the manual, it will explain all.
If you haven't got a manual then write to the manufacturer with proof of trade status and they will be happy to advise you further.
Regards
Bellman
If you cant work out the bell box connections, give up as the a 520 is a serious piece of kit.
The Galaxy is a serious piece of kit, but in it's simplest form of 16 on board zones, it isn't that bad is it? Why you would buy a Galaxy in this application would be puzzling.
Not sure about that Sounder but simply 12v and ov in the 12v and ov connections. The bell and strobe triggers go into outputs. These are programmed in menu 53 and should be programmed as "BELLS" and "STROBE". You could also program strobe as confirmed instead, this way the strobe will only go on a confirmed alarm. Alternatively you could install a big ugly red zit of a lamp on the front of your bellbox like Secom do! :)
The tamper goes into the tamper connection on the far right hand side of board, this should be a neg return. If your bell has a tamper loop then there is a handy 0v nearby.
Regards
Dave
Will you lot stop dissin my fave panel :P
cheers
they are a good panel and yes the 520 is a serious bit of kit,BUT if you can use a 16 or 16 + you should be able to wire any sounder/siren into any galaxy panel,as they are all sort of the same :yes:
That is if you have used one before??????? :hmm: ...if not honeywell run some great training courses B)
