Aux Out
Guest tom52
Should the Aux + and - look like a terminal with lots of little wires going into it?
(I tried uploading a picture of it but it said i couldnt)
just wondering if im right or i need some sort of terminal block or something,
got to be said tom you gotta different way of asking a question
AUX supplies auxillary equipment like pirs or vibration detectors, you may well have several wires attached here.
i'm guessing you are adding some detection, and a better/neater way for more than say 4 device supply wires, is to use a terminal block to combine the device power feeds, and then run a pair from this connector block into the aux terminals.
if you are tinkering with an installed system be very careful, there are 'tricks' engineers sometimes use, and your system may not work properly or at all after you modify it.
best option - if it aint broke - don't fix it!
hope that helps
regs
alan
