Guest junkdvc Posted September 19, 2006 Posted September 19, 2006 Hi, I have a gardtec 350+, which went off for no apparent reason whilst the alarm was unset, and since then the power LED is flashing. I have replaced the glass fuse inside the control panel, which had blown, but the power LED is still flashing. Is there just the one fuse inside the control panel? Please Help!
djrock Posted September 19, 2006 Posted September 19, 2006 Hello, When was the panel last serviced and when was the backup battery in the panel last changed? djrock
arfur mo Posted September 19, 2006 Posted September 19, 2006 Hi, I have a gardtec 350+, which went off for no apparent reason whilst the alarm was unset, and since then the power LED is flashing. I have replaced the glass fuse inside the control panel, which had blown, but the power LED is still flashing. Is there just the one fuse inside the control panel? Please Help! hi, make sure to close the lid properly then try your code twice to see if it clears, not used the 350 but most gardtec panels have to have the mains fail indicator reset after a power fail - draws your attention to it. regs alan If you think education is difficult, try being stupid!!!!
