Veritas R8 Problem
Guest hobbit1969
sorry fastcar did not know that, i must have only used the newer panel. there you go we are always learning thanks.
i agree with you the best solution is to reinstate the circuit on zone one, rather than link it out, if indeed there was a circuit on zone ( the panel in this case would seem to say there was) :)
Thanks for all your help with this guys. I('ll take a look at the panel when I get a moment.
By the way, in order to replace PIRs (using existing wiring in place), is it necessary to remove power from the panel first?
Thanks
again same info as before about the mains
it is always safer to work on a circuit that is dead, no voltage (even 12volts dc),
remove one of the wires form the the aux 12v power supply(supplying the particular pir) before changing pir.
warning - as little as 50 mille amps directly across you heart can kill you
What you have all missed is if zone 1 was the entry/exit cct. Hes in for a shed full of trouble to try to set and unset if its linked out.x
Just an observation.
cheers
very good point paul, the guy knows what to do now, but has being strongly adviced to reinstate circuit one by yourself and fastcar, and your post is the reason why. :)
  • 2 weeks later...
Guest teselec
HI all
Am i right in thinking you can replace a r8 keypad with a excel keypad on an existing r8 system, programming aside of course
cheers
HI all
cheers
say what?
r8 no, r8+ maybe depends how old the r8+ is?
