Guest deepblue55 Posted September 23, 2006 Posted September 23, 2006 hi there, it uses 2k2 resistors ...
Guest deepblue55 Posted September 23, 2006 Posted September 23, 2006 ill post a pic of the box soon so you can see what ive done ... if the pic posted is anything to go by (couldnt see too well) mine arent wired as EOL, the wires are directly wired into the control panel, with the resistors sittin on top (one leg is in the zone contact, the other in the common contact. is that Double EOL? ... im sorry i havent explained this very well but ill get a photo up asap
Guest Posted September 23, 2006 Posted September 23, 2006 Mr deepblue, it is all explained in the manual in pure english. this doesn't sound helpfull but you need professional help. your questions sounds like asking the way without knowing where to go. if you want to use EOL's first get to know what is resistor and where is end of the line.
mjw Posted September 23, 2006 Posted September 23, 2006 ill post a pic of the box soon so you can see what ive done ... if the pic posted is anything to go by (couldnt see too well) mine arent wired as EOL, the wires are directly wired into the control panel, with the resistors sittin on top (one leg is in the zone contact, the other in the common contact. is that Double EOL? ... im sorry i havent explained this very well but ill get a photo up asap I am not being funny if it is in the manual you just follow the diagram....if you cant call an engineer that can
Guest deepblue55 Posted September 23, 2006 Posted September 23, 2006 from how ive read the manual so far i think i have wired them up right, but the diagram doesnt explain very well how the PIRs wire in ive attached a pic of both the wiring diagram from the manual & a pic of the control box ... is there anything that is obviously wrong? thanks cant seem to get them to attach so here are the URLs http://classic.myob.co.nz/images/DSCF6272.JPG http://classic.myob.co.nz/images/wiring_diagram.jpg
mjw Posted September 23, 2006 Posted September 23, 2006 from how ive read the manual so far i think i have wired them up right, but the diagram doesnt explain very well how the PIRs wire inive attached a pic of both the wiring diagram from the manual & a pic of the control box ... is there anything that is obviously wrong? thanks not quite sure where you attached your pic toooooo,but it isnt here
Guest deepblue55 Posted September 23, 2006 Posted September 23, 2006 sorry, couldnt get them to attach but have added the URLs now
mjw Posted September 23, 2006 Posted September 23, 2006 from how ive read the manual so far i think i have wired them up right, but the diagram doesnt explain very well how the PIRs wire inive attached a pic of both the wiring diagram from the manual & a pic of the control box ... is there anything that is obviously wrong? thanks cant seem to get them to attach so here are the URLs http://classic.myob.co.nz/images/DSCF6272.JPG http://classic.myob.co.nz/images/wiring_diagram.jpg Well the diagram make perfect sense ...what you have done reall i am sorry tooo say doesnt from the diagram you should have 2 x 2.2 resistors per device(pir,contact,etc)...1 x 2.2 goes across your alarm relay another 2.2 goes from one side of your alarm relay to one side of your tamper pair.....this is all inside the pir......then your cable that comes from your panel (the alarm pair one is conected to the alarm relay and the other is conected to the other side of the tamper contact)...hope that make sense
Guest Posted September 23, 2006 Posted September 23, 2006 well thats just beautifully engineered.....
Guest Posted September 23, 2006 Posted September 23, 2006 actually the diagram only shows Single EOL connection but it is already irrelevant since you explained DEOL quite well..
