imperium Posted September 24, 2006 Share Posted September 24, 2006 How make connections between Panasonic WV-CW860A/G CCTV camera and PC base system? Witch PC base system you suggest? Link to comment Share on other sites More sharing options...
247 Posted September 24, 2006 Share Posted September 24, 2006 How make connections between Panasonic WV-CW860A/G CCTV camera and PC base system? Witch PC base system you suggest? This will work on many pc based systems, i have used it on A Geovision 800 card and a linux based Anextek no problems, on the Panasonic Dome when i did it about 2 years ago i had to cut the RJ45 lead and use the Green and yellow wires to connect to the GVnet, check your handbook for TRX and RX colours, http://www.henrys.co.uk/cctv/geovision-GVnet.htm Link to comment Share on other sites More sharing options...
