Alarm Interfering With Phone
Guest fastasflip
Guest fastasflip
Hi all hope you can give me a few pointers as I'm an alarm virgin :wub:
The house I have just moved into has a Veritas control panel it looks pretty old and has no LCD screen or model number on it. During the 4 weeks we have lived here the phone line has been extremley poor mainly due to a continous crackle but every now and then you can here a sound similiar to the one you get should you leave the phone off the hook.
Had a BT engineer around who Identified that the alarm was the problem and couldn't do much for us.
I can only assume that the alarm was monitored at some point but we dont need this facility. Ive had a look in the "brains" of the system and think I have Identified the phone wires however the alarm sounds when I pull any. Is there anyway around this or do I need an engineer
Many thanks in anticpation
It needs reprograming, an engineer is the only way i am afraid.
cheers
Veritas with coms ??
Yep, very scary I agree. :fear:
Veritas R8 Plus. Either that or comms of the bell relay, seen that loads of times! :no:
Dave
Dave
yep you are right..mind you have come accross an installer today who is still working/quoting to bs 4737 and still getting police response
how do they get away with it??????? :bruce_h4h:
Watch the R8 plus, if you delete phone lines you have to follow a sequence or it still thinks its connected..............nasty little things they were.
cheers
Yep there's has always been the R8+ with digi outputs there was also the the digitas with 8 channel digi built in the board, not forgeting the metal ones fitted with the plug on stu board under the pcb....
