Scanny9651 Plus Odessey3
south_side
Hi all
I have just installed this system in my house and I was wondering if there was anyway of getting a confirmation signal that the alarm had been set ? I have seen with a friends system which is an Abacus system that when he arms the system and leaves the house, the strobe in the bell box flashes to indicate it has been set.
Another question I have is that should I use the bell in SAB mode or not ? I just want your opinions
Thanks
Guest Peter James
You need to give more information, like what panel you are using would be a good start.
Pete
Guest Peter James
Pete
OPPS :huh: just read the topic title.
You should wire the system as sab, Im not sure whether scanny is able to strobe confirm set
Pete
:whistle:
The 9651 can be programmed to have the strobe confirmation on set.
Use the outputs as configured, then prog output 3 as strobe set and wire in series with the strobe output.
cheers
Wire from ouptut 2 to output 3 to oddessy 3 strobe input...............one line in series whats parallel about it?
click me
Series, one thru other single link.
Parallel, double cores.
Strobe is a neg trigger, thats all, a set to strobe for ten seconds requires no second core.
cheers
