Guest Buzz820684 Posted January 30, 2004 Posted January 30, 2004 I have an A1 AJ600 security system, but the external beelbox has packed up. Does anyone have the connection details for wiring up a C&K AG6 external sounder & strobe unit to the AJ600. Buzz
Guest oldtimer Posted January 31, 2004 Posted January 31, 2004 Ok first of all I do not have a wiring description for your sounder but this should be straightforward AJ600 ============================= external box Bell - ===========( blue cable ) ======= Bell- or trigger Bell + ========= ( red cable ) ==========sounder + STR - =========( green cable ) ======== ===str - or trig SCB RT ======= (yellow cable)=========== ==tamper return - SCB - ======= ( black cable ) =========== ===sounder - Hope this helps If you need more info mail me the connections of the AG6
