Guest helpappreciated Posted January 31, 2004 Posted January 31, 2004 Hi guys, I have been offered (new boxed with instructions and installation manuals) either a Scantronics 9750 or a 9800+. I would like to install the kit myself, or at least attemp to do so. I have checked the Scantronics web site and they no longer mention the 9750 but refer to the 9751. Is there anything i should be aware of in respect to the 9750? Was it discontinued for a reason? I do not want to buy a pup. I know that the 9750 has wirefree caperbility but that aside which alarm would you go for. The 9750 or the 9800? Great informative web site. I have sifting through the pages for a while now and you offer a lot of assistance to a lot of people. Thank you for any guidance you might afford me.
morph Posted January 31, 2004 Posted January 31, 2004 9750 was updated by a newer version the 9751, so simply its and improvement, if you have the choice as you say, I would go for the 9750 but the 9800+ is a very well proven panel to, essentially the 9750 has more features and is a newer fromula. As far as wired/ wirless goes stick with wired( do a search on the forum for wireless alarms and see why) If the system is only going to bells only or call a keyholder only then the above panels are okay but you will never be able to get a Police responce from the system if it is not proffessionally installed/maintained and you would need a newer version of the panel that complies with the current regulations. Colin.
Guest helpappreciated Posted January 31, 2004 Posted January 31, 2004 Hi Colin, Thank you for the much valued comments. I am sure once I start configuring the panel I will have a question or two more. If that is the case if any one can help me again at that point i would be most gratefull. Thanks again for your speedy reply. Kevin.
