Dialler Connected To Mobile Phone
Guest stoker
Hi all, i'm a spark by trade andi'm fairly new to the site but i've been asked to connect an autodialler to an alarm system thats on a boat. I've been told that its possible to connect an autodialler to a mobile phone, could anyone point us in the right direction as regards this ie brands of dialler, connections any adaptions needed etc. It may also need a new panel due to the code being mis-laid, anyone know of the best type of panel to use that makes best use of battery power? Any advice gratefully recieved!! Thanx
There is a similar thread here somewhere, who was using this sort of kit for a remote factory/storage unit?
Think arfur was involved in it somewhere.
cheers
Hi All,
that remote factory turned out to be holding exsplosives :cold2: . and we suggested radio linked detection. i have not used any gsm only diallers, and the boat owner would need to check signal on a particular network in the mooring.
one suggestion comes to mind though, it's a completely different product to a true alarm dialler as it's a bit of kit used on remote un-manned gate posts. you fit a sim card into it and when the call push is pressed it dials a sequence of pre-programmed phone numbers as entered into the Pay As U Go sim card by any mobile network.
any alarm fitted could use this as a 'dry contact' interface, and no message needed as the number will only be from the boat. having a remote option to open a gate via a relay output, and of course you have a speech path, so this could be used voice verify and to sound sirens whatever, and i think curent drain is also very small.
regs
alan
Your customer's name is not Bob by any chance is it?
cheers
Dave
cheers
Dave
Nah , chaps name aint bob, I'm a Phelps though! But no, theres no mains available at the boat. Time between charges as long as poss really, owner suggested using a 60ah car battery said i'd get back to him on that one.
Just wondered.
Well if you get this thing working, e-mail me as I have got a guy in Tewkesbury who wants the same thing. I don't want to do it as I will have to support it from Weston-super-Mare.
cheers
Dave
Does a wanderer panel have a gsm built in then?
Just had a look on the castle web site, that wanderer panel looks like a pretty top spec panel, is there anything it wont do!? But also noticed that its currently not in production which i thought was strange, (surely should remove its listing then).But like you said Jameswilson looks like it would be big bucks anyway.
