Scantronic 9651 Panic Alarm
south_side
Hello
I have just installed this system and the manual claims that by pressing buttons 1&3 should activate the panic alarm but mines does nothing, can you help ?????
Thanks
it comes out of the box with that feature disabled, you need to be in engineers to do that.
cheers
Unless you have the engineers code your not going to be able to do anything about it.
cheers
Derr at my reply, we just sorted you out with the strobe stuff.
Go to option 87, scroll with A and B till you see PA press 1 to enable.
then get out of engineering and press 1 & 3 it will make some noises :P
cheers
Go to option 87, scroll with A and B till you see PA press 1 to enable.then get out of engineering and press 1 & 3 it will make some noises :P
cheers
option 87 then 1 then tick
this will enable the pa function
And Make Sure You've Not Accidently Programmed 30 As Silent
woods for trees syndrome there lads :fear:
Pull the link out of output 3 though south.
cheers
why do I need to remove the link old hand ?
Because you can programe the strobe to activate for ten seconds as a set indication on its own output. No need for output 3 now.
cheers
PS its a few replies above here how to prog it.
From The Other Post About Strobe Set, I Believe
