Texecom Flush Mounted Keypad Question
Guest andymarshal
Guest andymarshal
Hi guys i have brought a house with a vr8 alm installed, i was told it was installed about 6 months ago. One of the key pads is in a real nasty spot and i would like to replace it witha flush mounted version instead.
something like:
http://www.alertelectrical.com/Burglar-Ala...eypad-White.asp
will this be ok or is there another flush panel that would work?
Just need to know before i start ringing round for someone to do it.
Thanks
Andy
something like:
Thanks
Andy
Andy
The keypad you have shown is for the Premier range of control panels.
The standard R8 takes only the LED keypad, which doesn't come in a flush mounted version. The R8+ and Excel have the option of an R8 LCD Keypad (not premier), but I am pretty sure this also does not come with the flush mount option.
If you are set on flush mount then get a quote to replace the main control panel to a Premier 24 and a flush remote keypad.
Regards
Dave
Agreed.
Have you made a mess in your bed?
Agreed.
No mate :lol:
Early bird catches the worn !!
Dave
