Carbon Monoxide Detector
Guest aechlin
Guest aechlin
Hello, I have a Thorn SGU601 Carbon Monoxide detector, from an //.National Installer.// system and I am trying my hardest to get the wiring information for it. It has four terminals, R, L, L1 and L2 on the base. I intend to connect it to the last free zone on my alarm panel to act as the fire zone.
Any help would be greatfully recieved
Thank You
Alistair
Guest aechlin
Hmmmm, ok, so if I managed to supply it with 24 volts how would I connect up the alarm switch side of the detector? I may need to use an opto-isolator to trigger the panel.
Thank you for your very much for your quick response :)
cheers
Alistair
Guest aechlin
Well thank you for explaining this to me, would have been spending lots of time on this for nothing. I see now its not as straight forward as I anticapated.
cheers
Alistair
Guest graemekeatley
With regards to how to wire them
Negitive - L
Incoming Positive - L1
Outgoing Positive - L2
EOL between L2 and L at last device
You can fit these detectors to a normal intruder system and //.National Installer.// were using these in Residential systems. One of the //.National Installer.// guys should be able to confirm the wiring and eol setup. They operate over a voltage range of 9volts up to 24volts.
Colin.
Guest aechlin
Well, thank you all for the responses, it is connected up and working as it should be doing.
Again many thanks, hope I can be of any assistance to anyone on this great forum!
Alistair :D
if you want to test it
buy some cheep joss sticks from your local knick knack shop
it should go within 10 - 30 secs
put joss stick about 10 cms from detector
:wacko::wacko::wacko:
  • 2 weeks later...
do bear in mind they are NOT smoke detectors , but CARBON MONOXIDE (CO) detectors, which also means if you have a faulty gas appliance they WILL activate
