Guest McD Posted February 1, 2004 Posted February 1, 2004 I am trying to install an Aritech cs350. This is DIY, and I am no expert. Problem is that on powering up the panel, the keypad displays "CS350 V3.3", but will not respond to any input. Manual says it should ask for languages, etc. If I am honest, I am not 100% sure when wiring the bell, what to do with the tamper loop. It is a bit confusing reading the panel manual and the SAB instructions. Specifically whether the resistor goes in the panel, or in the bell box. I have put it in the bell box(says to do this for standards). I have wired 4 of the 6 core bell cable into the panel at positions 4 & 5 (external bell) and at 6 & 7 (internal bell). Questions are... 1. Do remaining 2 go into positions 16 and 17 ? 2. Which is which ? 3. Do I also need a resistor across 16 and 17 in parallal ? Any help is welcome.. McD
mr silcox Posted February 1, 2004 Posted February 1, 2004 check you keypad wiring and that you have correctly set the dip switches on keypad
Guest McD Posted February 1, 2004 Posted February 1, 2004 Yeah, I think all appears ok there. The Keypad wiring is pretty straight forward , A-12, B-13, C-14, D-15 I left the ID at the default which is correct for a single keypad, i.e. all off. Thanks, McD
