Veritas 8
Guest Lee
:angry: Following a power cut and all exhausted batteries, I have just reset to factory defaults and reprogrammed everything including the user & engineer codes. I can access everything using engineer code + 00.
When I try to programme the Miscellaneous Selections with engineer code + PROG, all I get is an error beep. The zone lights do not come on and I can't access anything.
Am I missing something or may the panel be faulty?
cheers,
Lee
panel fine its you........ ;)
Guest Alarm Guard
I think you have got a Mk1 panel and Mk2 instructions.
Where did you get the engineering instructions from?
Paul
Thanks Mr Happy...
(note to myself) - Must try to be as helpful as this person when someone asks for my help!
Alarm Guard...
All the instructions and documentation are what came in the box with the panel when I bought it new.
Guest Alarm Guard
I give in then. Maybe Mr Happy is right. :hmm:
Thanks Mr Happy...
pleasure :P
where did you get it from & when?
I have successfully used the instructions when the system was first installed. It's only since the power cut and having reloaded factory defaults that I can't access these Miscellaneous Selections. I've read the installation manual through thoroughly, three times now.
Maybe I can't see the wood for the trees...
Lee
:hmm: ... and that makes what difference to the problem?
It's well out of any warranty before you suggest taking it back to the supplier.
there a load of different pcb's which have software differences.... your DIY job?
with a double zero maybe 5ish years old?
