Guest jamiet
recently moved house which has an alarm 9448 i have not got an idea of the manafactuer or an instruction book ,
my father recently tried to move the sensor therefore setting the tamper alarm off, i pushed my 4 figure digit code in which stopped the tamper alarm but the light was still on,
it then went off again and again so i turned the alarm off in the fuse box.
it then decided to go off outside, the only way i could shut it up was pull the fuse switch out above the alarm cutting the power to it.
could someone advise me the next step to take to get this up and running again,
or some info on the alarm type reset codes etc
any help would be gratefully appreciated
thanks jamie
