Weatherproof Prox Reader Help??
brad2512
Hi, I need a weatherproof reader for setting/unsetting a system im about to install, does anyone know of any manufacturers which have these. I have found a way to do it with a remote and reciever but its expensive. Its not a big install but the customer wanted it this way so theres would be no entry route without disarming first. Any help appreciated, Thanks
Pyronix Prox-R sounds like it would fit the bill if the panel in question has a keyswitch option for set/unset. The PCB is set in epoxy, so it's weather proof, but you might want to seal around the unit with clear silicone after install to stop moisture getting onto the terminals.
Trade Member
The Aritech ATS panel has an outside reader which sits on the data line and arms/disarms the system. It has a built in buzzer and led indication for setting. :groupwave:
SSAIB Approved.
If it ain't broke, you ain't trying hard enough
guardtec do one for their 800 range
weve been looking at it from" the single room shop perspective"
it comes with small magnetic shunt locks so you can set everything to N/A and get confirmed for monitoring purposes without the need for an Entry Timer or Entry route which in a single room shop would leave it slightly exposed
Life is like a box of choclates.....if you dont get there first your left with all the naff ones
cheers ive just had a look at the pyronix reader which would be ideal for it :) , im assuming it just works as a kind of keyswitch no/nc? does anyone know a rough price of these also i need an economy panel which has keyswitch set option. cheers
careful with these as if you remove the reader you could disarm the alarm
As James says, but the scanny 9651 has keyswitch facility.
cheers
Dave! Dave! Dave! Vandamme swore you should kick him out, he said ATS :fear:
I don't see why the ATS (sorry couldn't find a spit emoticon), can't see why the ATS prox reader doesn't comply?
It acts as an access reader and three swipes of the fob and the system sets. One swipe in the morning and this unlocks the door and unsets the alarm.
Won't help the OP though, can't see him having an ATS installed.
cheers
Dave
Gardtec 595, or the CPX for small instal. they do internal and external readers and work a treat. go a bit further fit radio rx and radio fobs, how much more weather proof do you want?
:hmm: problem with no exit/entry timer is user's will set from outside, that means they will not see any error or advisory messages on ths display when setting, and unlikely to read it when unsetting i.e. activation, low batt , mains fail etc.
so nothings purfect :rolleyes:
regs
alan
