Guest jonathan574 Posted October 11, 2006 Posted October 11, 2006 Early am had a large thunderclap above the house. Alarm box (intellisense ag8) sounder triggered in battery mode. No Strobes. The keypad for galaxy panel showed no alarm status. Only way to silence was to remove battery link from the sounder box and kill power and disconect battery at the panel. sounds like a new sounder box to me is this a common occurance.
Guest Posted October 11, 2006 Posted October 11, 2006 It could still be the panel locked up, may be an idea to have someone come and check the alarm over for you.
Guest rjbsec Posted October 11, 2006 Posted October 11, 2006 Lightning is causing more severe problems than ever, it is not uncommon for a complete system to be wiped out - even if ancilliary equipment appears to work fine, lightning can cause damage to chips that only shows up months down the road.
black knight Posted October 11, 2006 Posted October 11, 2006 tell me about it..................... last time round i was mopping up cctv systems - casmeras, muxes etc for weeks paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
whistle Posted October 11, 2006 Posted October 11, 2006 We are a North West based company give us a call and we will callout and repair it for you.
Guest jonathan574 Posted October 11, 2006 Posted October 11, 2006 yeah your galaxy survived but the bell didnt, lesser panels would probably have keeled over too, but lighting is so powerfull you dont know how much damage it will do. Not common but lighting does indeed damage intruder alarms, cctv, routers, sky boxes tv.'s... etc etc Thanks for the info, are some bell boxes more sensitive than others? my easy option is to replace like with like but if you know of any more robust options let me know
mjw Posted October 11, 2006 Posted October 11, 2006 Thanks for the info, are some bell boxes more sensitive than others? my easy option is to replace like with like but if you know of any more robust options let me know i think all bells(if struck by lightning)would'nt be that robust at all!!!!!!!!!!!!!!!!!!!!!
mjw Posted October 11, 2006 Posted October 11, 2006 id go for a lightning proof decoy model lol.Nothing can take lightning not even the ground i would go for the decoy model as well...it will never give you a false alarm
arfur mo Posted October 11, 2006 Posted October 11, 2006 imo if above 12 feet from ground best to avoid matal clad or metal shielded ones, as they atract more lightning hits pro-rata than mainly plastic sirens. many systems damaged in storms are not as a result of a direct hit, but the induced high voltage's in cables or metal covers after a local strike, this is what fries the eletronics. the direct hits are easier to diagnose, sniff for an ackrid smell, and look for the sight of a pile of ashes on the floor below, where once was the control panel on te wall. regs alan If you think education is difficult, try being stupid!!!!
Guest rjbsec Posted October 11, 2006 Posted October 11, 2006 My experience is that by far the majority of lightning problems come down the telephone line.
