camerabloke Posted October 15, 2006 Posted October 15, 2006 QUOTE(SnowBum @ Oct 14 2006, 04:49 PM) * in my line of work if you guess at parameters you could end up causing 10s of thousands of pounds worth of damage to an expensive CNC machine tool. Pretty much the same here whistle.gif more like tens of pounds Eucam Security Systems 0845 4630 746 www.eucam.co.uk
black knight Posted October 15, 2006 Posted October 15, 2006 The PIRs aren't latching but i have placed all PIRs facing into the rooms not looking at radiators or sources of heat (one exception is the hall PIR which looks down the hall at the front door but since the sun never faces the door i'm hoping that it'll be ok). I've already filled the cable holes with silicon sealer (thought that if i plaster/fillered the holes i might need to pull some cable through at a later date and have to get it out again and it'd be a bitch). All cables have been ran away from mains, they only cross mains at right angles. There aren't any runs parallel with mains. I'm thinking of putting it on soak test for a few days just to make sure i haven't got any areas of false alarms and i don't want to annoy the neighbours. My concern would be post coming through letter box (assuming you have one). A cold source ie letters or large letter/envelope can sometimes activate a PIR. Apart from that you seemed to have done a good job for a amateur. As others have commented the thing about multiple detectors on zones is 'bad practice' but you obviously have the knowledge to fault find the problem if one occurs. If we did that as a proffessinal job we would get criticsed by our inspectorate(s) hence the comments you receieved. As a service engineer myself if i need to attend a premises where a pir has activated there nothing worse than finding a zone with 2 (or more!) sensors on it. If you are lucky they are latching type but more often they are not and have just been wired like this for cheapness and quickness. It is a touchy point therefore with most of us. But your posts have indicated to me at least that you planned your installation and have a diagnostic plan if oyu do have faults well done paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Guest Posted October 15, 2006 Posted October 15, 2006 what about part p wheres the mains come from??has the mains been certed?? He's not said nowt about the mains yet The mains is a direct feed from the consumer unit from its own 6A MCB through a 3A fused outlet box. Whoops he now needs to ring building control...... more like tens of pounds The alarm protects the building & its contents in the case of a motor showroom or bonded wharehouse there may be over a million quid worth of responsibility knocking about if things are bodged together, How much is someone
camerabloke Posted October 15, 2006 Posted October 15, 2006 He's not said nowt about the mains yet Whoops he now needs to ring building control...... The alarm protects the building & its contents in the case of a motor showroom or bonded wharehouse there may be over a million quid worth of responsibility knocking about if things are bodged together, How much is someone Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest Posted October 15, 2006 Posted October 15, 2006 i was being sarcastic you really need to try harder something along these lines? I assume a CNC machine is largely controlled by programmable logic controls? Where a status input of a control circuit provides a selected response sounds strangely familiar to me
camerabloke Posted October 15, 2006 Posted October 15, 2006 yep, thats good have to get sarcasm lessons off ya Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest Posted October 15, 2006 Posted October 15, 2006 yep, thats goodhave to get sarcasm lessons off ya I think your getting the hang of it
camerabloke Posted October 15, 2006 Posted October 15, 2006 I think your getting the hang of it changed sig now, as i am a fully fledged member of your club Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest Posted October 15, 2006 Posted October 15, 2006 changed sig now, as i am a fully fledged member of your club Gosh I fell like a proud Mr Miyagi, wax on , wax off ect....
Guest Posted October 15, 2006 Posted October 15, 2006 BS 47437 1988........ Dolls house? on the vodka (again) i was referring to 'technically' term - not req's..
