C&k Securitech 800l
Guest AndrewRoss
Guest AndrewRoss
I have recently moved into a house fitted with a Securit 800L control panel, along with 4 PIR's and 1 PA alarm (I have the User Manual). The PIR's are Zone 1 (Front Door and Back Door PIR's), Zone 2 (Lounge PIR) and Zone 3 (Landing PIR). I have cats and want to leave them whilst I am away and still be able to set as much of the alarm as is possible. To do this I need to isolate Zones 1 and 3, preferably I would like to make it so that the 2 PIR's in zone 1 are seperated, is this done through the control panel (just with a code) or does the wiring have to be physically changed to allow this? My second question is when isolating the zones using the full set, night set or home set I am unable to isolate Zone 1, but can isolate any of the other zones. Is there some way that I can get around this? Thank you very much for any help regarding this! (if the wiring needs to be changed I will have to ring a professional installer, as it is something that I would be unable to do myself)
Guest AndrewRoss
you will need to chnage the wiring, plus it will need reprogramming to allow you to omit the e/e zone (1), plus they will reprogram your part sets
Roughly how much would something like that be likely to cost? Just so I don't get ripped off! Also, thanks for your reply!
Guest AndrewRoss
again it depends, from my point of view if it were us etc etc
call out charge would be
